Den Fehler hatte ich bereits schon 2015 reklamiert, nun reagiert FCA doch noch. Obwohl beim 2,0 CRD die Anzeige auch falsch ist, gibt es da aber kein Update.
Zitat von FCAAlles anzeigen2016 -2018 (KL) Jeep Cherokee
NOTE: This recall applies only to the above vehicles equipped with a 2.2L diesel engine.
Subject
The change engine oil indicator on the vehicle cluster on about 15,700 of the above vehicles may have an incorrect setting for the “Change Engine Oil” notification which will display on the instrument cluster at the wrong km range to have the engine oil changed. Delaying the engine oil change may cause premature engine wear.
Repair
Reprogram the PCM with the latest available software
